The Working Planes Palette
The Working Planes palette displays working planes that have been set or saved while working on a drawing. The palette allows you to save new working plane positions, and to edit, duplicate, delete, activate, and select existing working planes. Combine these features with the working plane controls on the View bar, the working plane commands on the Modify menu, the Set Working Plane tool, and the Align Plane tool to accurately control the placement and alignment of objects in 3D space.
To manage working planes in the Working Planes palette:
  1. Select Window > Palettes > Working Planes.
  2. The Working Planes palette opens.
  3. Click the Utility Menu button at the bottom of the Working Planes palette to open the Utility menu.
  4. Alternatively, right-click (Windows) or Ctrl-click (Mac) on the palette to access the context menu.
    Menu/Command
    Action
    New
    Saves a new working plane; see Saving Working Plane Positions
    Edit
    Edits the currently selected working plane; see Editing and Renaming Working Planes
    Duplicate
    Duplicates all currently selected working planes
    Delete
    Deletes all currently selected working planes
    Activate
    Activates the currently selected working plane. Alternatively, double-click an existing working plane from the Working Planes palette to activate it.
    Select
    Activates the currently selected working plane, if it is not already active, then executes the Select Working Plane command to display the grip handles for the plane
  5. Select the desired command.
Accessing Existing Working Planes
Working Plane View and Modes
Working Plane Commands
The Active Planes List
vectorworks.net
