Managing Saved Export Options
The Manage button under the Settings heading of the DXF DWG Export Options (or DWF Export Options) dialog box renames or deletes sets of export options when needed.
To manage saved DXF/DWG or DWF export settings:
  1. Select File > Export > Export DXF/DWG (or Export DWF). The appropriate Export Options dialog box opens.
  2. Click Manage.
  3. The Saved Settings dialog box opens. Select the set of saved export options to change.
  4. Click OK to close the Saved Settings dialog box. Click OK again to close the export options dialog box.
DXF/DWG and DWF Export Options
vectorworks.net
