DesignSeries00259.pngWing Nuts - Type D
To insert a type D wing nut:
  1. Click the Wing Nut - Type D tool from the Fasteners tool set.
  2. Multiple wing nut tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
  3. Click to place the object in the drawing, and click again to set the rotation.
Wing Nuts
Wing Nuts - Type A
Wing Nuts - Type B
Wing Nuts - Type C
vectorworks.net
