Angle Between One Reference Line and an Object
To dimension an angle between one reference line and an object:
  1. Click the Angular Dimension tool from the appropriate tool set/palette, and select the Reference Line and Edge mode.
  2.     All workspaces: Dims/Notes tool set
        Spotlight and Landmark workspaces: Basic tool palette
  3. From the Tool bar, select a Dim Std (dimension standard).
  4. Click to set the start of the reference line.
  5. A reference line preview displays.
  6. Click again to set the end of the reference line.
  7. The cursor changes to a pointing hand.
  8. Click the edge of the object (and, therefore, angle) to dimension.
  9. An angular dimension preview displays.
    To select a different angle—for example, spanning the opposite direction—move the cursor until the preview displays the desired angle.
  10. When the preview displays the desired angle, click again to draw the reference line and to define the angle of the dimension.
Angular Dimensioning
Editing Dimensions
vectorworks.net
