Converting Objects to Dimensions
To convert a line, double line, or arc to a dimension:
  1. Select the object to convert.
  2. Select Modify > Convert > Convert Object to Dimension.
  3. The object is converted to a dimension. Lines change to linear dimensions, and arcs change to angular dimensions.
Editing Dimensions
vectorworks.net
