DesignSeries00091.pngEditing Slope Valleys
Slope valleys, which are formed by the intersection of two slab planes, can be edited and deleted using context menu commands that are available when the Slab Drainage tool is selected.
Editing Slope Valley Properties
When created, slope valleys receive the default slope, and their elevation at the edge is computed based on the drain height and the intersection with the slab edge. The control point elevation is based on the valley’s initial direction and the nearest bounds of the slab perimeter. If you opt to define the slope valley by the elevation of the control point, the slope is automatically recalculated based on the location and height of the control point and the drain.
To edit slope valley properties:
  1. Select the slab object.
  2. Click the Slab Drainage tool from the Building Shell tool set, and then click Edit mode from the Tool bar.
  3. Right-click (Windows) or Ctrl-click (Mac) on one or more slope valleys and select Edit Valley(s) from the context menu.
  4. The Valley Settings dialog box opens.
  5. Edit the properties and click OK.
Rotating Slope Valleys
Slope valleys can be rotated individually, or all slope valleys associated with a specific drain can be rotated collectively.
To rotate slope valleys:
  3. To rotate one or more individual slope valleys by the same percent, select the slope valleys, then right-click (Windows) or Ctrl-click (Mac) on one of the slope valleys and select Rotate from the context menu.
  4. Alternatively, to rotate all slope valleys associated with a specific drain, right-click (Windows) or Ctrl-click (Mac) on the drain and select Rotate Valley(s) from the context menu.
    The Rotate dialog box opens.
  5. Specify the clockwise angle by which to rotate the slope valleys, and click OK.
The slope valleys are rotated.
Deleting Surface Folds Related to Slope Valleys
If two slope valleys are adjacent to a drain valley, the resulting surface may have a fold, so that a single, planar surface cannot be created. A line displays where the fold is. Depending on the size of the fold and the construction material being used, this may not be a problem. If the fold is above 0.1%, an indicator line displays so it can be corrected.
If the roof geometry results in a fold, the Vectorworks software determines from which drain to start the fold line using three criteria. First it uses the drain with fewer connections to other drains. If both drains are equally connected, it uses the drain with the steeper valley slope. If both valleys are equally sloped, it uses the drain for the slope valley that has an angle closest to the drain valley. If all factors are equal, either drain may be used.
To remove a fold, right-click (Windows) or Ctrl-click (Mac) on one of the slope valleys adjacent to the fold and select Remove Fold(s) from the context menu.
The slope, and possibly also the direction, of the slope valley is changed. This may result in a slope valley slope less than the allowable minimum; you may need to change the slab to correct this problem.
Deleting Slope Valleys
To delete a slope valley:
  3. Right-click (Windows) or Ctrl-click (Mac) on one or more slope valleys and select Delete from the context menu.
The slope valley is deleted.
Drains and drain valley networks must have slope valleys sufficient to define all the slopes surrounding them. This means valleys cannot be deleted if they leave a greater than 150-degree angle between the remaining markers, or if a valley is the only valley between two non-collinear drain valleys.
Editing Slab Drainage Elements
vectorworks.net
