All Vectorworks products include three types of common cabinets for inserting in a drawing file—base, wall, and utility cabinets. In the Vectorworks Fundamentals product, the cabinet objects are inserted from an object library through the Resource Manager. In the Vectorworks Design Series products, the cabinet objects are inserted with the various cabinet tools. Cabinet door and drawer handles are provided in the Vectorworks libraries; see Concept: Resource Libraries.
In addition to these common cabinet types, Vectorworks offers the flexibility of Creating Custom Cabinets.
To insert a base cabinet in the Vectorworks Design Series:
To insert a utility cabinet in the Vectorworks Design Series:
To insert a wall cabinet in the Vectorworks Design Series:
Click the Base Cabinet, Utility Cabinet, or Wall Cabinet tool from the Furn/Fixtures tool set.
Do one of the following:
● To use an existing object from the resource libraries, click Active Def on the Tool bar. From the Resource Selector, double-click a resource to activate it. Click on the drawing or wall to place the object, and click again to set the rotation.
● To create a custom plug-in object, click Preferences from the Tool bar. From the Object Properties dialog box, set the default properties and click OK. Click on the drawing or wall to place the object, and click again to set the rotation. The properties can be edited from the Object Info palette.
Click here for a video tip about this topic (internet access required).
