All Vectorworks products include shelving units for inserting in a drawing file. In the Vectorworks Fundamentals product, the shelving units are inserted from an object library through the Resource Manager. In the Vectorworks Design Series products, the units are inserted with the Shelving Unit tool.
In addition to these common shelving units, Vectorworks offers the flexibility of Creating Custom Cabinets.
To insert a shelving unit in the Vectorworks Design Series:
Click the Shelving Unit tool from the Furn/Fixtures tool set.
Do one of the following:
● To use an existing object from the resource libraries, click Active Def on the Tool bar. From the Resource Selector, double-click a resource to activate it. Click on the drawing or wall to place the object, and click again to set the rotation.
● To create a custom plug-in object, click Preferences from the Tool bar. From the Object Properties dialog box, set the default properties and click OK. Click on the drawing or wall to place the object, and click again to set the rotation. The properties can be edited from the Object Info palette.
