The current custom cabinet object, along with all its parameters, can be saved as a symbol for use again in the current file or in a library file. The cabinet is saved as a red symbol and becomes a plug-in object with pre-set parameters when inserted. See Symbols.
To save the custom cabinet as a symbol:
From the Base pane of the Custom Cabinet Settings dialog box, click Save as symbol.
The Save as Symbol dialog box opens.
Select whether to save the custom cabinet symbol in the current file or in a library file.
● To save the symbol in the current file, select Save as symbol in current document, enter a name for the symbol, and select a symbol folder destination for the symbol by double-clicking on the selected symbol folder name
● To save the symbol in a library file, select Save as template in library file and enter a name for the symbol
Click OK.
● If the symbol was saved in the current file, it is available from the Base tab’s Symbol list under the Current Document category, and also from the Resource Manager. Symbols can be shared by exporting them from the Resource Manager (see Exporting Resources).
● If the symbol was saved in the user default library, it is available from the Base tab’s Symbol list under the Custom Defaults category. Library files can be shared among users.
