Arch.pngCreating IFC Schedules
Before you export an IFC project, check that objects have appropriate IFC data associated with them. In the Vectorworks Architect product, the following schedules with IFC data can be added to the drawing with the Choose Schedule command, or you can create your own schedules (see Using Preformatted Schedules).
    Objects with IFC Entity gives a count of IFC objects for each entity type on each layer. The object class, name, and type also display, if available.
    Objects with IFC Entity - Specific lists each IFC object, broken down by entity type (walls, slabs, roofs, doors, windows, stairs, and columns). The object layer, class, name, and description also display, if available.
    Objects without IFC Entity lists each non-IFC object. The object layer, class, type, and type name also display, if available.
Alternatively, from the Resource Manager, select Vectorworks Libraries\Defaults\Reports_Schedules\Architectural Reports.vwx. Drag the appropriate IFC worksheet to the drawing.
To edit the worksheets after they have been created, see Using Worksheets.
IFC Format Interoperability
Resource Manager
vectorworks.net
