DesignSeries00015.pngIFC Data Mapping Expressions
IFC mapping formulas calculate and display the values of certain property set parameters, mapping BIM data to IFC-compliant data. Custom mapping can be created and used for custom property sets.
Mapping and associated formulas display in the IFC Data dialog box; formulas can be mapped and edited from the IFC Data Mapping dialog box.
●    In the IFC Data dialog box, the existing mapping displays in the Data Source parameter of the selected property (see Assigning IFC Data to Objects).
●    In the IFC Data Mapping dialog box, the mapping formulas of the selected data sets of an object are displayed on the right portion of the dialog box (see Creating or Editing a Data Mapping Formula). These mapping formulas can be created or edited from the Define Mapping dialog box, which is accessed by clicking Define Mapping.
Viewing the default data mapping formulas in the IFC Data Mapping dialog box helps you understand the data source of the mapped IFC values. Expressions can be used to customize the automatic data mapping formulas.The results of the expression calculations are assigned to the Data Source parameter.
Each formula consists of one or more expressions from the following list. The expressions are described in more detail in the rest of this section.
Expression
Description
Constants
Types of data, such as integers, Boolean constants, numbers, and text constants
Fixed values
Text strings, numerical and logical values, and so on
Operators
Addition, subtraction, comparison, and so on
Variables
Vectorworks data sources, such as object parameters, style information, class name
Functions
Mathematical functions, string manipulations, conditional functions, and more
ELSE
Method of adding alternative data mapping, if the previous one yields an empty value
Constants
Constants are written as follows.
Constant
Description
Examples
Boolean
Values are used for Boolean parameters, and are either true or false, written as string constants enclosed within apostrophes
‘FALSE’
‘TRUE’
Integer
Positive or negative numbers and 0, written as numbers with no decimal point or apostrophes
4
125
Rational number
Real number values, written as a number with a decimal point and no apostrophes
3.14
-12.0
248.141539
Text
String values enclosed within apostrophes
‘Unstyled Wall’
‘INTERNAL’
‘NOTDEFINED’
Operators
The supported operators are listed.
Operator
Description
Unary Plus
Unary Minus
Binary Plus, Addition, Concatenation
Binary Minus, Subtraction
Multiplication
Division
Logical EQUALS
Logical NOT
Logical OR
Logical AND
Logical NOT EQUAL
Greater than
Less than
Greater than or equal
Less than or equal
Variables
Variables represent sources of data from Vectorworks. They can be combined with constants, function results, and other variables by using operators. The variable type (name) is the same as that of the data source type. Variables are enclosed by square brackets, since spaces are permitted in the name.
The supported variables are listed.
Variable
Format
Example
Parameters from an object
[Object.NameOfTheParameter]
[Object.Config]
[Object.Column ID]
[Object.Struct Type]
Vectorworks name
[Object.VW_Name]
[Object.VW_Name]
Record field data from a record format
[Record.NameOfTheRecord.NameOfTheField]
If a record by that name is not attached to the object, then the default value of the record field is taken as the value of the variable.
[Record.MyRecord.Price]
[Record.Plant Record.Latin Name]
Data from style
[Style.NameOfTheField]
Currently supported data fields are: Name (the name of the style), Mark, Function, Description, Exterior (Boolean), Load-Bearing (Boolean), Fire Rating, Combustible Construction (Boolean), Compartmentation (Boolean), U-Value, Acoustic Rating, Cost Index System, Cost Index Code, Model, Manufacturer.
[Style.Function]
[Style.Name]
[Style.Fire Rating]
Class name
[ClassName]
[ClassName]
Layer name
[LayerName]
[LayerName]
Functions
The supported functions are listed.
Function
Description
PI ( )
SIN (radians)
Returns the sine
COS (radians)
Returns the cosine
ABS (number)
Returns the absolute value
SQRT (number)
Returns the square root
LEFT (text, index)
Returns the left-side of the string, split by position index (0 is the position of the first character). Returns an empty string if the index value is incorrect.
RIGHT (text, index)
Returns the right-side of the string, split by position index (0 is the position of the first character). Returns an empty string if the index value is incorrect.
MID (text, index, count)
Returns the right-side of the string, split by position index (0 is the position of the first character) and having a count of characters. Returns an empty string if the index or count values are incorrect.
FIND (text, subtext)
Returns the zero-based position of subtext in text, if found, or -1 if not found
IF (logical_expression, value_expression1, value_expression2)
Calculates logical_expression and returns the calculated value of value_expression1, if TRUE, or value of the value_expression2, otherwise
SELECT1 (number_expression, value_expression1, value_expression2, …, value_expressionN)
Calculates number_expression and returns the calculated value of value_expression1, if the result is 0, value of the value_expression2, if the result is 1 and so on. Returns the value of the last expression, if the result is bigger than N-1. The number of the function parameters must be 3 or more.
SELECT2 (logical_expression1, value_expression1, logical_expression2, value_expression2, …, logical_expressionN, value_expressionN)
Calculates the first logical expression and returns the calculated value of value_expression1, if the result is TRUE; otherwise, continues with the next logical expression and value expression pair. The number of the function parameters must be even, and greater than 2.
IFC Data Mapping Examples
Managing IFC Data Mapping
vectorworks.net
