Managing IFC Data Mapping
Configuration SetsThe current mapping configuration can be saved.
To save the current mapping configuration as a set:
From the IFC Data Mapping dialog box, click Save.
The Save Mapping dialog box opens.
Provide a name for the configuration set, and select whether to save the mapping of all the objects in the list, or only the mapping of the currently selected object in the Object list.
Click OK.
If you have saved IFC data mapping settings, click Manage from the IFC Data Mapping dialog box to rename or delete these saved settings.
To manage saved settings:
From the IFC Data Mapping dialog box, click Manage.
The Manage Saved Mapping dialog box opens. Select the saved mapping configuration set to change.
Click OK to close the Saved Settings dialog box.
