Importing
a Revit FileRevit files (.rvt or .rfa) created in versions 2011 through 2017 can be imported. A Revit entity object is created, containing the graphics from the imported file. If possible, portions of the imported geometry are converted into a corresponding Vectorworks object.
To import a Revit file:
Select File > Import > Import Revit.
Select the Revit file to import and click Open.
An alert dialog box displays the import progress.
The geometry of a selected Revit entity can be edited by clicking Edit Geometry from the Object Info palette.
