 Importing in Shapefile Format
Importing in Shapefile FormatThe Vectorworks Architect and Landmark products can import files in shapefile (.shp) format. Each geometric feature stored in the shapefile is converted to a Vectorworks object. In turn, each of these objects has a corresponding data record, which is converted from the shapefile’s database file.
To import a shapefile and select conversion options:
Select File > Import > Import Shapefile, and then select the shapefile to import.
Alternatively, click the file to import and drag it into an open Vectorworks file.
The Vectorworks program determines the appropriate units for the imported objects from the projection (.prj) file, if one is available. If no projection file is found, the current document’s units are used.
The Import Shapefile dialog box opens. Specify the file import options.
Click OK to import the file with the selected options. The Object Info palette displays the imported shapefile information.
