Placing Lighting Pipe LaddersThe Lighting Pipe Ladder is a is a three-click rectangular object, and can be inserted in Center-line Placement mode or Edge Placement mode.
Placement Mode |
Description |
Center-line |
Click once, and then again, to define the length through the center of the ladder. Click again to specify the ladder width |
Edge |
Click once, and then again, to define the length along the edge of the ladder. Click again to specify the ladder width. |
To insert a lighting pipe ladder:
Click the Lighting Pipe Ladder tool from the Spotlight tool set, and then click a placement mode from the Tool bar.
Click in the drawing area to insert the ladder.
To use the lighting pipe ladder as a lighting position, convert it to a lighting position object; see Creating a Lighting Position Object.
