Generating Paperwork The information to be included in the various schedules and reports, as well as the format of the reports, is specified in the Generate Paperwork dialog box.
The Choose Schedule command automatically creates certain reports as preformatted worksheets; see Using Preformatted Schedules.
To set up the schedule and report information:
Select Spotlight > Reports > Generate Paperwork.
The Generate Paperwork dialog box opens.
Select the desired Schedules and Reports. Each schedule and report selected must be set up by clicking on its Setup button. The setup procedure is described in the following sections.
Configure the rest of the paperwork setup by entering the Header Configuration, Event Information and the Page properties. Click OK to generate the desired paperwork with the specified settings.
