Editing Object Surfaces
Editing 2D Object Surfaces
There are four commands for editing 2D and 2D/3D hybrid object surfaces: Intersect Surface, Add Surface, Combine into Surface, and Clip Surface. The Intersect, Add, and Clip commands have an equivalent context menu command accessed by a Ctrl-click (Mac) or right-click (Windows). Use these commands with the following objects.
Vectorworks Fundamentals Objects
    2D primitive objects that can be filled and are not grouped (arcs, polygons, polylines, ovals, circles, rectangles, rounded rectangles)
    Revision clouds
    Floors
    Roof faces
    Pillars
Vectorworks Design Series Objects
    Ceiling grids
    Plants
    Massing models
    Stipples
    Property lines
    Redlines
    Site modifiers
    Seating layouts
    Spaces
    Hardscapes
    Parking Areas
    Stages
    Slabs
These commands work in any view, as long as the objects involved are in the same plane. If a combination of 2D and 2D/3D hybrid objects (such as floors or pillars) will be used in an operation, the view must be set to Top/Plan. In Top/Plan view, screen plane and layer plane are considered to be co-planar.
The equivalent 3D commands operate on solids and can be used in a 3D view.
Intersect Surface
Add Surface
Clip Surface
Editing 3D Object Surfaces
vectorworks.net
