The Publish command lets you select multiple sheet layers and saved views to export, both from the current file and from other files in a selected folder. The functionality depends on your Vectorworks license.
License |
Functionality |
Vectorworks Fundamentals product |
Export DXF/DWG, DWF |
Vectorworks Design Series products |
● Export DXF/DWG, DWF, PDF, image formats |
Vectorworks Service Select subscription (all products) |
Export DXF/DWG, DWF, PDF, image formats With Vectorworks Cloud Services, the processing is done on the cloud server instead of on your computer. The generated files are available from the Vectorworks Cloud Services web portal, the cloud processing folder on your desktop computer, and the Vectorworks Nomad mobile app. Learn more about Vectorworks Cloud Services at vectorworks.net/cloudservices. For details about using the Vectorworks Cloud Services web portal, cloud publishing, and mobile apps, select Cloud > Help. |
For each publish item, you can set custom options, and select either color or black and white output. If you use the Issue Manager (Vectorworks Architect or Vectorworks Landmark required), you can sort the list by issue date for quick publishing. To make custom publishing faster and easier, save the sets of files and options that you use frequently.
This dialog box has specialized functions to sort and select its list items; see List Box Functionality.
To batch publish sheet layers and/or saved views:
Set up the sheet layers and/or saved views for publishing.
Set the visibility of layers and classes in the viewports and views. All visible and grayed layers are published. Invisible layers and classes are not printed or published to PDF or DWF; they can be published as invisible DXF/DWG layers, if the option is selected in the DXF/DWG Export Options dialog box. Each sheet layer or saved view is published as a separate file.
If you plan to use the cloud publishing feature, select Cloud > Log In/Sign Up to log into Vectorworks Cloud Services. Then select Cloud > Open Vectorworks Cloud Services Folder, and place the files to be published in the folder. Alternatively, if you have enabled Dropbox integration, place the files in your Dropbox folder.
Select File > Publish or Cloud > Cloud Publish (Vectorworks Service Select subscribers only).
The Publish dialog box opens.
The sheets and saved views in the active file display in the left pane of the dialog box. To expand the list to other files, click Select Folder and select the folder where the files to be published are located.
If you plan to use the cloud publishing feature, first select either Cloud Services or Dropbox Storage from the storage list, and then select the folder.
If you plan to publish several items, set the following options before you add items to the publish list:
● From the Add New Items as list, select the default format for publish items.
● Enter a Prefix Name to be added to the published file names.
Select available items from the list in the left pane of the dialog box, and use the buttons in the middle of the window to move them to the publish list in the right pane of the dialog box. Alternatively, double-click an item (or press Shift and double-click multiple selected items) to move it to the publish list. The Publish To column in the right pane indicates the current output setting for each item.
To publish an item to multiple formats, select Show All Items; add the item to the publish list multiple times, and specify a different format for each one.
To set custom output options, select one or more items from the publish list and click Options.
When all publish settings are complete, click Publish. If the file has not been saved to the Cloud Services or Dropbox storage folder specified, an alert displays; click Save Now to save the file and continue.
If the publish set has not been saved, you are prompted to save it.
If PDF, DWG/DXF, DWF, or Image is a selected publish format, the Select Folder dialog box opens. Specify a location for the output and click Select Folder.
If there are files in the selected folder already, you are prompted to confirm that you want to continue.
If you published to either Cloud Services or Dropbox storage, a status dialog box opens to display the progress of the cloud publishing.
The output files are printed or created based on the selected settings. A publish log file is created in the output folder.
Click here for a video tip about this topic (internet access required).
You can save the current publish settings to be reused later. The set of sheet layers and saved views (including prefix name, list order, publish method, color settings, and custom options) is saved in the active file. If the file set contains sheet layers and views from a selected folder, specify how to save the path relative to the active file.
To save the export list as a set:
In the Publish dialog box, click Save a Set.
The New Saved Set dialog box opens.
Click OK. The settings are saved with the active file and are available for future publish jobs.
After you have saved a set, you can recall it to publish the same set again. There are also options to edit and delete saved sets.
To manage saved publish sets:
In the Publish dialog box, select the storage type for the set to be recalled: Local, Cloud Services, or Dropbox storage.
Click Manage Sets.
The Manage Saved Sets dialog box opens.
Edit or delete sets, as needed.
To simply close the dialog box without recalling any saved sets, click Close. To recall saved sets, select one or more sets and click Recall.
The settings for the selected saved sets display in the Publish dialog box, with the following exceptions.
● The recalled set may not show all of the original items, if the saved set is opened on a computer that has a different Vectorworks product installed. For example, if you open a set with the Vectorworks Fundamentals product (and no Vectorworks Service Select subscription), no PDF items display. Also, if the storage type is set to Cloud Services or Dropbox Storage, no Print items display.
● If the saved set includes sheet layers or saved views that cannot be located, you are prompted to manually locate a missing file, or warned that sheets or views are missing. Missing sheets and views display in red in the Publish dialog box, and are not included in the publish job.
