When a resource is deleted, all instances of the resource in the active file can be deleted completely or replaced with a different resource of the same type.
To delete a resource:
From the Resource Manager’s file browser pane, select the active file.
Right-click (Windows) or Ctrl-click (Mac) on the resource to delete, and select Delete from the context menu.
Alternatively, select the resource and press the Delete key.
If there are any instances of the resource currently in the drawing, the Delete [resource] dialog box opens. Otherwise an alert displays to confirm the deletion.
Click Yes.
The resource is deleted and each resource instance is either deleted or replaced with the selected resource.
You can select multiple resources to delete at the same time. However, the option to replace instances of the deleted resource with a different resource is available only if all the resources selected for deletion are of the same type, such as all gradients or all record formats.
