Use the import function of the Resource Manager to import one or more resources from any file to the active file, without opening the source file.
To import resources:
From the Resource Manager’s file browser pane, select any file other than the active file.
Select one or more resources to import.
Right-click (Windows) or Ctrl-click (Mac) on the resource, and select Import from the context menu.
The Import Resource(s) dialog box opens.
Click OK.
If the active file already contains a different resource with the same name, the Resource Name Conflict dialog box opens with three options: replace the resource, rename the resource, or do not import that resource (any other selected resources will be imported, if there are no further name conflicts). Select an option, and then click OK.
A fast way to import is to simply drag and drop one or more resources from any file or folder to the active file in your Open Files list.
