DesignSeries00020.pngEditing Issue Data
When a US Arch title block is added to a sheet border, an area for issue data is included. The issue notes are specified in a separate dialog box.
To add or edit issue data:
  1. From the Object Info palette of a selected sheet border with a revision block, click Edit Issue Data.
  2. The Edit Issue Data dialog box opens.
  3. Click Add to create an issue entry.
  4. The Add New Issue dialog box opens. Specify the issue note.
  5. Click OK to return to the Edit Issue Data dialog box. Existing issue notes can also be edited or deleted.
  6. Click OK. The issue data is updated.
Sheet Border Properties
vectorworks.net
