DesignSeries.pngEditing Revision Block Data
To add a revision block to the sheet border, select Use Revision Block from the Object Info palette of a selected sheet border. The revision block parameters (such as height and width) are specified from the Object Info palette, but the actual revisions are specified in a separate dialog box.
To add or edit revision block data:
  1. From the Object Info palette of a selected sheet border with a revision block, click Edit Revision Data.
  2. The Edit Revision Data dialog box opens.
  3. Click Add to create a revision entry.
  4. The Add New Revision dialog box opens. Specify the revision data.
  5. Click OK to return to the Edit Revision Data dialog box. Existing revisions can also be edited or deleted.
  6. Click OK. The revision block is updated.
Sheet Border Properties
vectorworks.net
