Internal Origin and User Origin
The center of a Vectorworks drawing has fixed coordinates of (0,0); this location is called the internal origin. A user origin also exists. Drawing coordinates display relative to the user origin. Normally, the internal origin, the user origin, and the page center are all coincident. While the internal origin cannot move, the user origin and page center can be moved.
Depending on the design needs, and for some imported files (to maintain the imported file’s coordinates), the user origin needs to shift so that the user origin location is different from the internal origin. One reason to change the origin is to make it easier to work with coordinates, measurements, and distance values. For example, the Swiss use a reference point system for architectural measurements, where everything is in relation to a point in Europe. When a building is located at a site, that site is referenced to be a certain distance and direction from this point. Using this system creates large numbers on the ruler and in the Object Info palette. In the User Origin dialog box, you can shift the user origin close to the building site so that the system does not display large coordinates.
Changing the user origin can have far-reaching consequences. Use caution when changing the user origin.
Commands allow you to locate the internal origin and center the drawing on it, and to set the user origin.
Locating the Internal Origin
Centering the Drawing on the Internal Origin
Setting the User Origin
vectorworks.net
