The Break Line tool creates one of three types of break lines: straight, curved, or arc.
On site models, pads with open edges, sometimes called break lines, can be created using the Site Modifier tool (Vectorworks Architect or Landmark required). See Creating a Pad or Pad with Retaining Edge.
To draw a break line:
Click the Break Line tool from the Dims/Notes tool set.
Click to place the object in the drawing, and click again to set the rotation.
