Line into Segments
The Line into Segments command converts a selected line into the indicated number of equal length segments. The original line can be converted, or an identical line placed on top of the original and converted.
To convert a line into segments:
  1. Select the line to be converted.
  2. Select Modify > Drafting Aids > Line into Segments.
  3. The Line into Segments dialog box opens.
  4. Set the parameters and click OK to draw either a new segmented line or convert the selected one.
Creating Single Lines
Creating Double Lines
Create Dividing Lines
vectorworks.net
