Loft Surface Using Two Rails
To create a loft surface using two NURBS curve rails:
  1. Click the Loft Surface tool from the 3D Modeling tool set, and then select Birail Sweep from the Tool bar.
  2. Click on each rail, and then click on the cross section. The cross-section profile curve does not need to intersect the rail curves.
  3. In this mode, only one cross section can be selected.
  4. Once the profile curve is selected, press Enter or click the check mark button on the Tool bar.
  5. The Loft Creation dialog box opens.
  6. Specify the desired loft creation settings (see Loft Surface Using No Rails).
  7. Click OK to close the dialog box and create the loft surface.
The loft surface is created differently depending on whether the profile curve is open or closed, and how the start/end of the rails touch the profile curve. In certain instances, the click order (which rail is clicked first) and location (part of the profile curve that is clicked) will produce a different loft surface.
Status of Profile Curve and Rails
Effect of Rail Click Order/Profile Click Location
Open Profile Curve
Start/end of one of the rails touches the start/end of the open profile
The rail click order and profile click location do not affect the loft surface creation
Start/end of the rails do not touch the start/end of the open profile, or do not touch the open profile at all
Both the rail click order and the location where the profile is clicked affect how the loft surface is created
Closed Profile Curve
Start/end of one of the rails touches the closed profile curve
The click order and location do not affect the loft surface creation
Start/end of the rails do not touch the closed profile at all
The click order affects how the loft surface is created
Creating a Loft Surface
vectorworks.net
