DesignSeries00073.pngSpecifying Global Grade Object Preferences
The grade indicator appearance for all grade objects in the file can be specified globally.
To set global grade object appearance:
  1. Click the Grade tool from the appropriate tool set:
  2.     Designer and Landmark workspace: Site Planning tool set
        Architect and Spotlight workspace: Building Shell tool set
  3. Click Preferences from the Tool bar. Alternatively, select an existing grade object; click Settings from the Object Info palette, double-click the grade object, or right-click (Windows) or Ctrl-click (Mac) on a grade object and select Edit from the context menu.
  4. The Grade Settings dialog box opens. Click the Global Settings tab and enter the desired settings.
  5. Click OK to set the global grade indicator attributes.
  6. Click Update from the Tool bar to update all grade objects in the drawing with the global settings.
Calculating Grade for a Site Model
Applying Object Attributes
Inserting Grade Objects
Analyzing Grade
vectorworks.net
