DesignSeries00015.pngCustomizing Space Labels
The Vectorworks Design Series products provide several space labels, which you can use or modify. You can also create custom labels, import a space label symbol from another document, or convert a symbol in the current document into a space label.
Custom space labels are symbols that are designated as space labels from the Space Settings dialog box. Like any other symbol, by default a custom label is only available in the document in which it is created. To make a custom space label available from the Space Settings dialog box for all of your documents, use the Save as Default option to save the label to a template file. The Space Default template file is created in your user folder automatically, in [User Folder]\Libraries\Defaults\Space\Space - Stamp.
To share custom space labels with a workgroup, create a template file that contains the labels (see Creating Space Labels). Place the file in the workgroup’s default labels folder. The labels then display on the list of available symbols on the Space Label pane of the Space Settings dialog box. See Customizing the Space Settings.
Editing Existing Space Labels
Converting Symbols into Space Labels
vectorworks.net
