Inserting Elevators
The Elevator tool inserts an elevator into a wall, with options for front and rear doors.
To insert an elevator:
  1. Select the Elevator tool from the Building Shell tool set.
  2. Do one of the following:
    To use an existing plug-in object resource, click Active Def on the Tool bar. From the Resource Selector, double-click a resource to activate it. Click on the drawing or wall to place the object, and click again to set the rotation.
    To create a custom plug-in object, click on the drawing or wall to place the object, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default properties, and click OK. The properties can be edited from the Object Info palette.
vectorworks.net
