Cutting 2D Sections
From the Vectorworks Fundamentals workspace, the Cut 2D Section command (Vectorworks Fundamentals workspace only) cuts a 2D section, or a slice, from a 3D model without affecting the model. The slice is then placed on a new design layer. For example, to show the profile or a 2D cutaway section of an object in a mechanical 3D drawing, use this command to create the cutaway section in 2D quickly and easily, without affecting the original object.
To cut a 2D section from a 3D model:
  1. Select the 3D model to section.
  2. Select Model > Cut 2D Section (Fundamentals workspace only).
  3. Click to set the start of the section. Draw a line across the object to define the section, and then click to set the end of the section.
  4. When cutting a section while the drawing is in Top/Plan view, the cutting plane (and the cut edge of the object) is perpendicular to the active layer plane.
    When cutting a section while in a 3D view, the cutting plane is perpendicular to the working plane.
  5. Click on one side of the line to indicate the portion of the model to keep.
The Vectorworks program automatically creates a new design layer and places the cut 2D section on it. The original layer remains intact.
vectorworks.net
