Removing Wall Breaks
The Remove Wall Breaks tool cleans up any wall breaks or gaps that were created during editing. For example, when creating a new wall that joins an existing wall, if the new wall is later deleted, a break in the remaining wall displays at the joint. The Remove Wall Breaks tool can remove the break and any end caps.
To remove wall breaks:
  1. Click the Remove Wall Breaks tool from the appropriate tool set:
  2.     Fundamentals workspace: Walls tool set
        Design Series workspaces: Building Shell tool set
    Alternatively, right-click (Windows) or Ctrl-click (Mac) on the wall and select Remove Break from the context menu.
  3. Click and drag to create a marquee box around the wall break or end cap to remove.
The wall break or end cap is automatically removed.
Reshaping Walls
Joining Walls
Joining Walls with the Fillet Tool
vectorworks.net
