Entering Data in Spreadsheet Cells
Three types of information can be entered into the spreadsheet cells of a worksheet: constant values (including text or numbers), formulas, and images (Vectorworks Design Series required). In addition, a cell can reference another cell in the same worksheet or in another worksheet.
    Text helps to identify the purpose of a worksheet and labels the columns in a worksheet.
    Images add visual information about items on a worksheet, and can also be used to create a drawing legend (Vectorworks Design Series required).
    Use formulas to perform calculations based on drawing data. A formula can be a simple mathematical equation, or it can include one or more built-in functions. The Vectorworks program provides mathematical functions (for example, a square root function), as well as functions that pull information from drawing objects (for example, a function that returns the volume of selected objects). See Worksheet Functions for a list of the functions available.
Database record fields that are attached to objects in the drawing (such as Model Number or Price) cannot be used in a spreadsheet cell. To include this type of data in the worksheet, see Entering Data in Database Rows.
To define a spreadsheet row:
  1. Right-click (Windows) or Ctrl-click (Mac) on the number of the row to change.
  2. From the Row context menu, select Spreadsheet.
  4. The cells in the row are empty until you define the contents. Select a cell, and then enter the desired information in the worksheet Formula bar located at the top of the worksheet.
    To enter text or numbers, see Entering Constant Values in Worksheet Cells.
    To enter a formula, see Entering Formulas in Worksheet Cells.
    To reference other cells in this cell, see Referencing Other Worksheet Cells.
    To insert an image, see Inserting Images in Worksheets.
vectorworks.net
