Viewing Received DMX
When a lighting console is connected, you can view the incoming DMX information from the console.
To view the DMX information:
  1. Select Dmx > DMX Viewer.
  2. The Dialog box opens.
  3. Specify the protocol to connect to the lighting console, and click OK.
  4. The DmxView dialog box opens. This is a separate dialog box that opens along with Vision, and it can remain open while Vision is in use.
  5. For each selected Universe, the current DMX information being sent from the console displays. The Display Type can be toggled between Decimal and Percentage.
  6. To close the DmxView, click the X.
The Patch Tool
