DesignSeries00040.pngCreating North Arrows
Use the North Arrow tool to indicate the drawing orientation, in a variety of configurations. The deviation from true magnetic north can be displayed on some of the configurations. If the design layer is georeferenced, the object is rotated to point in the proper direction.
North arrows maintain a constant size regardless of the drawing scale.
To create a north arrow:
  1. Click the North Arrow tool from the Dims/Notes tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Using Notation Objects
Inserting a Heliodon Object
