Creating Reference Markers
Use the Reference Marker tool to indicate the drawing number and sheet number of a referenced drawing, in a variety of configurations.
Reference markers maintain a constant size regardless of the drawing scale.
To create a reference marker:
  1. Click the Reference Marker tool from the Dims/Notes tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Using Notation Objects
The Attributes Palette
Formatting Text
Using Text Styles
