ArchLand.pngCreating Revision Markers
Use the Revision Marker tool to indicate the drawing revision number.
Revision markers maintain a constant size regardless of the drawing scale.
To create a revision marker:
  1. Click the Revision Marker tool from the Dims/Notes tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Using Notation Objects
