ArchLand00059.pngIndicating the Slope of Surfaces
Use the Slope Dimension tool to indicate the slope of any angle that is perpendicular to the screen.
To create a slope indicator:
  1. Click the Slope Dimension tool from the Dims/Notes tool set.
  2. Click to mark the beginning of the slope. Click again to mark the end of the slope.
Using Notation Objects
