Managing Saved Import Options
The Manage button on the Import Options dialog box renames or deletes sets of import options when needed.
To manage saved DXF/DWG or DWF import settings:
  1. Select File > Import > Import Single DXF/DWG (or Import Single DWF), and select a file to import. The appropriate Import Options dialog box opens.
  2. Click Manage.
  3. The Saved Settings dialog box opens. Select the set of saved import options to change.
  4. Click OK to close the Saved Settings dialog box. Click OK again to close the import options dialog box.
DXF/DWG and DWF Import Options
