Linear Roller
ChainsThe 2D linear roller chain is a linear object, while the 3D linear roller chain is a point object.
To insert a linear roller chain:
Click the Roller Chain - Linear tool from the Machine Components tool set.
Multiple linear roller chain tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out Tools list and select the desired tool.
Click to place the object in the drawing, and click again to set the rotation.
