Angle Between Two Object Edges or Faces
To dimension the angle between the edges or faces of two objects:
  1. Click the Angular Dimension tool from the appropriate tool set/palette, and click the Edges mode.
  2. ●    All workspaces: Dims/Notes tool set
    ●    Spotlight and Landmark workspaces: Basic tool palette
  3. From the Tool bar, select a Dim Std (dimension standard).
  4. Click the edge or face of the first object.
  5. A preview line displays.
  6. Click the edge or face of the second object.
  7. An angular dimension preview displays.
    To select a different angle—for example, spanning the opposite direction—move the cursor until the preview displays the desired angle.
  8. Click a third time to define the radius of the dimension.
Angular Dimensioning
Editing Dimensions
