Radial Dimensioning Inside Circle/Arc
The Interior Radial mode measures and dimensions the radius of a circle or arc, and places the dimension inside the object.
To create a radial dimension inside a circle or arc:
  1. Click the Radial Dimension tool from the appropriate tool set/palette, and click Interior Radial mode.
  2. ●    All workspaces: Dims/Notes tool set
    ●    Spotlight and Landmark workspaces: Basic tool palette
  3. From the Tool bar, select a Dim Std (dimension standard).
  4. Click on or within the arc or circle to dimension.
  5. Move the cursor to preview the dimension line location.
  6. Click to place the dimension.
Radial Dimensioning
Editing Dimensions
