DesignSeries00054.pngAdding Symbol Geometry to a Slab
A symbol or plug-in object, such as a skylight, can be inserted into a slab. The symbol geometry modifies the slab while inserting itself into the slab, similarly to the way a door or window is inserted into a wall. Symbols with a hole-cutting component (3D wall hole component) cut the slab.
To add a 3D symbol to a slab:
  1. Select both the slab and the 3D symbol.
  2. Select the Add 3D Object To Slab command from the appropriate menu:
●    Architect workspace: AEC > Add 3D Object To Slab
●    Landmark workspace: Landmark > Architectural > Add 3D Object To Slab
●    Spotlight workspace: Spotlight > Architectural > Add 3D Object To Slab
The symbol is inserted into the slab.
The symbol can only be selected and modified in Edit Modifiers mode.
Changing the Slab Modifier
Editing Slab Geometry
Adding a 3D Wall Hole Component to a Symbol Definition
