DesignSeries00001.pngWorkflow: IFC Export
Generally, IFC-compatible applications are set up to work with an entire project (sites with buildings consisting of stories) in a single file. When you select the Export IFC Project command, you assign design layers to building stories for meaningful export (Vectorworks Architect required). For a project initially set up with stories, mapping is done automatically so that the layers assigned to the building stories are automatically included in the Mapped Layers list and are mapped to an appropriately named IFC Story. Mapping can also be controlled manually, allowing you to override or edit the automated process or make any subsequent changes. The Import IFC command automatically assigns each IFC building story to its own design layer.
To make Vectorworks building models easy to export to IFC, the following guidelines may be useful.
●    Set up the project initially with stories as described in Setting Up the Building Structure with Stories (Vectorworks Architect required).
●    Design layers for the building model should correspond to building stories (Vectorworks Architect required), not categories of information. (Use classes for categorization.)
●    Take care to set up the elevation values of layers correctly, and verify that all the objects in the drawing are correctly aligned vertically. Examining the project in Unified View mode makes this much easier.
●    Use standard Vectorworks plug-in objects listed in IFC Format Interoperability wherever possible; the IFC data are already attached to these objects.
●    Use the IFC Data command to attach IFC data to custom user-defined hybrid or 3D symbols, custom 3D elements, or auto-hybrid objects, so that they will be recognized at IFC export.
●    Manage the IFC data with the IFC Data Mapping command, attaching IFC data sets to objects that do not already have them, selecting objects and property sets for export, and defining mapping formulas. See Managing IFC Data Mapping.
●    Set up project data in the IFC Export dialog box (see Exporting IFC Projects), and save the settings for use when creating reports. No actual export is needed before running IFC and COBie reports based on the data.
●    Use the Create Report command to generate default IFC or COBie schedules, or create your own schedules to verify and correct the IFC data attached to objects. See Using Preformatted Reports.
Default worksheets include both a final COBie format report and an associated working report with “Help” in the worksheet title. This worksheet reports not only the values of the COBie properties but also the source data for each; this should make it easier to find and correct drawing information that causes undesirable final data.
●    Test the quality of the IFC export file by verifying it in an IFC model viewer. Almost all IFC viewers can traverse the IFC hierarchical “tree” structure to view and validate the model.
For information about available IFC viewers and other IFC-compatible applications, visit the buildingSMART IFC-Compatible Implementations Database website or IfcWiki.org.
●    If you receive comments or corrections for the project in BIM Collaboration Format (BCF), use the Open BCF Manager command to view the notes, and then correct the project file (see Managing BCF Information).
Assigning IFC Data to Objects
Assigning IFC Data to Zones, Systems, and Groups
Viewing and Editing IFC Data
Using Custom IFC Property Sets
Creating IFC Schedules
Importing IFC Files
