Creating
Label LegendsTo create a new label legend:
In the Label Legend Manager dialog box, click Add.
The Add New Legend dialog box opens. Select the labels for placement and specify their attributes. Indicate the instrument symbol to use when formatting the label legend, and select whether the legend rotates with the instrument.
Custom container symbols can be added to the list of available containers. Draw a container object, and then click Modify > Create Symbol. Enter a name for the container; click OK. In the Move Symbol dialog box, specify the location of the Containers folder and click OK. The symbol is added to the list of available containers. Any symbol can be placed in the containers folder and used as a label container. The pre-defined container symbols can also be edited and customized.
Container attributes can be determined by the label text or lighting device; see Lighting Device Setup.
When all the label items and attributes have been specified for the legend, click OK. The new legend name displays in the Legend Name list in the Label Legend Manager dialog box.
Once the legend has been created, it needs to be formatted. See Formatting the Label Legend.
