Inserting
 a Photometer
To insert a photometer:
Ensure that each lighting instrument contributing to the illumination is focused.
The light beams do not have to be drawn for calculations to be made.
Click the Photometer tool from the Spotlight tool set.
Click to place the object in the drawing, and click again to set the rotation.
After placing the photometer, set its Z value from the Object Info palette; illumination values vary depending on the photometer’s elevation.
