The Intersect Solids command creates a single model from the volume created where two or more 3D objects intersect.
To intersect solids:
Select the two or more 3D objects to combine.
Select Model > Intersect Solids.
A single solid model is created from the objects; it is the size and shape of the overlapping volume of the selected objects.
