DesignSeries.pngImporting  an Adjacency Matrix Spreadsheet
To import an adjacency matrix:
  1. Ensure that the file to be imported is a tab- or comma-delimited file.
  2. Select AEC > Space Planning > Import Adjacency Matrix. The Import Adjacency Matrix dialog box opens. Specify the adjacency matrix file import options.
  3. The Import Adjacency Matrix command is available for Vectorworks Landmark and Spotlight software but is not present in the those workspaces. It can be added to the Landmark and Spotlight workspaces (see Customizing Workspaces).
  4. Click OK to import the adjacency matrix. If this is the first time an adjacency matrix, stacking diagram, spaces, or space links are placed in the file, a properties dialog box opens for each type of object. Set the default properties, and click OK. The properties can be edited from the Object Info palette.
Inserting an Adjacency Matrix
