 Replacing
 Roof Styles from the Object Info Palette
Replacing
 Roof Styles from the Object Info PaletteRoof styles applied to existing roofs can be replaced with a different roof style.
A roof replacement situation may also occur if pasting a styled roof from another file.
To replace a roof style:
Select one or more roofs.
From the Object Info palette, select Replace from the Style list.
The Roof Replacement dialog box opens.
If roofs with different roof styles were selected for replacement, the current roof preview is blank and components do not display.
Click OK to replace the roof style of the selected roof.
