Specifying Lighting Device Parameter Display
The lighting device parameters that display on the Shape tab of the Object Info palette can be customized. The customized parameters apply to all lighting devices in the file, and parameter sets can be saved.
To specify lighting device parameters:
  1. Select File > Document Settings > Spotlight Preferences.
  2. The Spotlight Preferences dialog box opens. Click the Lighting Device tab.
  3. Click Lighting Device Parameters.
  4. The Lighting Device Parameters dialog box opens. From this dialog box, Object Info palette parameters for lighting devices can be added, renamed, deleted, removed from display, and ordered. Parameter sets can be saved and managed.
    Default lighting device parameters cannot be deleted.
  5. If settings have been changed, save the current settings as a set by clicking Save; <customized> is not considered as a saved set, though it applies to the current file.
  6. Click OK to return to the Spotlight Preferences dialog box. The specified parameter display set applies to the current file.
Regardless of whether Save as default is clicked in the Spotlight Preferences dialog box, the last selected saved set of parameters is in effect, even when creating a new file. New files created in Vectorworks Spotlight always default to the last saved parameter set.
Lighting Device Setup
Lighting Device Properties
Concept: Record Formats, Reports, and Schedules
