Displaying the Server Operating Status
Several different tables list the operating status of the Vectorworks Site Protection Server. You can view the RLM statistics (web server statistics), ISV statistics (vektorwrx statistics), and the current license usage statistics.
RLM Statistics
Access: Click Status from the main Server Administration screen. RLM server information and server statistics are displayed.
Description: Shows the overall operating time and communication status of the RLM server.
ISV Statistics
Access: Click Status from the main Server Administration screen to access the Status screen. From there, click vektorwrx from the Server Status column.
Description: The vektorwrx statistics show the load information of the ISV server. For more information, see ISV Server Status.
License Status
Access: Click Status from the main Server Administration screen to access the Status screen. From there, click vektorwrx from the License Usage column.
Alternatively, click Status from the main Server Administration screen to access the Status screen. In the License Pool area, click Usage in the Show License Usage column.
Description: As described in License Usage Status, currently used licenses are shown.
Parameter
Description
Product
The name of the module
Pool
The pool number
Ver
The version number
User
Displays the user name
host
Displays the name of the host using the license
PID
Shows the product ID
req ver
The Vectorworks version that was requested by the client
#lic
Shows the number of licenses used by each user
#res
Shows the number of reserved licenses
Out time
Shows the start time for using the license
In (hold) time
Shows the scheduled day to return the license (for a borrowed license)
Click to REMOVE
Returns the license currently in use to the Vectorworks Site Protection Server.
This operation is only available for licenses connected to the network. It does not work for borrowed licenses.
If a Windows service is installed with the rlmdown command disabled, as described in Server Startup Options, then this button does not display.
Main Server Administration Screen
